Dual Print Cooling Fans
Hey guys,
I'am using the Radds 1.5 Board for my Dual Extrusion 3d Printer.
Is it possible to configurate two Print Cooling Fans so if i use nozzle 1 the first cooling fan is used and if i use nozzle 2 the second cooling fan is used?
i looked in the Repetier configuration but cant find such an option for dual extrusion
Best regards
Mane
Best regards
Mane
Normal solution is that all filament cooling fans turn on. If you always want fan 100% you could do so in slicer extruder switch code, but normally you want first layer with fan of.
Maybe the planned structure on firmware 2.0 will allow that the signal switches with the active extruder.
