Extruder don't turn anyway (two extruders) and second hotend is dead
Hello forum,
i have al lot of problems with my extruders and all i found doesn't help... It's my first printer - so i am lost without any reference...
About the envnironment:
I am configuring an delta printer with mega2560 and an Ramps 1.4, Repetier Firmware V0.92.9 and Repetier Host V2.0.1.
What is working:
- The printer does his homing and an Z-Probe on tree points.
- First hotend heat up correct (connected to D10) and the thermistor got correct values.
- Heatbed (4x M2KB), connected via a relay-board to D8 (own constuction), heats correct up and thermistor got correct value.
- moving the dual printer head manualy works fine. Moving it on a dry testprint works fine.
- first and second extruder got an holding torque on startup.
My Problems:
- First extruder won't turn manualy in hot state of the hotend on 200C
- First and second extruder won't turn manualy in cold state (M302 S1 sended) - no error messsages
- First extruder won't turn in a testprint in hot state of the hotend on 200C without filament (no sensor at extruder for noFilament)
- Second extruder don't heatup (connected to D9) but thermistor works while heating with my fingers
- after start of heating second hotend, printer jumps after 12s (as configured) in dry mode because no heat at hotend
- First and second extruder turn completely torqueless after first command to turn. holding torque resume only after reset.
- i got no error displayed in repetier host
I got the discussions "extruder not moving" and some others - they are not fixing my problem - i think i`ve tested the discussed errors.
...now it is the second weekend trying and testing without any step further...
I post my config in the following post.
I hope on your experteese
What is working:
My Problems:
#define CONFIGURATION_H
#define NUM_EXTRUDER 2
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 6
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET -25
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 85
#define EXT0_TEMPSENSOR_TYPE 14
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 78
#define EXT0_HEAT_MANAGER 0
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_WAIT_RETRACT_TEMP 160
#define EXT0_WAIT_RETRACT_UNITS 5
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 25
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 85
#define EXT1_TEMPSENSOR_TYPE 14
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 1
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 0
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 60
#define RETRACTION_Z_LIFT 0.5
#define FILAMENTCHANGE_Y_POS -140
#define FILAMENTCHANGE_Z_ADD 10
#define FILAMENTCHANGE_REHOME 2
#define FILAMENTCHANGE_LONGRETRACT 920
#define JAM_STEPS 200
#define JAM_SLOWDOWN_STEPS 300
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 14
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 310
#define MAX_DEFECT_TEMPERATURE 320
// ## Laser configuration ##
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 640
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 700 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 250
#define ROD_RADIUS 300.659
#define PRINTER_RADIUS 300.659
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 50
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 200
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 40
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 25
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET -25
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 3
#define Z_PROBE_HEIGHT 1.3
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -120
#define Z_PROBE_Y1 -100
#define Z_PROBE_X2 120
#define Z_PROBE_Y2 -100
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 120
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "FatBoy"
#define UI_PRINTER_COMPANY "Matthias"
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 210
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 85
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
#define UI_SET_MAX_HEATED_BED_TEMP 100
#define UI_SET_MAX_EXTRUDER_TEMP 295
#define UI_SET_EXTRUDER_FEEDRATE 5
#define NUM_MOTOR_DRIVERS 0
#endif
Fan uses also D9 by default so it overwrites your heater setting set it to 0 or set FAN_PIN to th epin where you have connected a fan (if you have a fan extender).
For extruders you have
while for xyz you have set it to 0. Wrong value here will disable extruder motor on moves and enable it when not moving. Try also opposite value here.
the second information - i think i havn't understood it...
Changing
#define EXT1_ENABLE_ON 1 --> #define EXT1_ENABLE_ON 0 will shitch off the second exturder.
I haven't seen some definitions in xyz for extruders, so could you give me the lines i should change?
(I have the same effect on EXT0 and EXT1)
Is there a descrition for all the defineable option in the configuration?
(maybe like a documented configuration.h)
I would like to understand all the other options too for optimization of my configuratuion :-)
Thanks 4 your help
Config tool has some context help and our homepage describes much as a whole. I'm also working on a new config tool that will have also more help included to help.
The working configuration is:
#define FEATURE_FAN_CONTROL 0
#define EXT0_ENABLE_ON 0
same configuration like xyz because of same driver - as you mentioned :-)
I had this EXT... configuration with the wrong FEATURE_FAN_CONTROL tested before.
There I got no reaction of the extruders - so maybe this thread helps others.
Many thanks for the quick help - you are great!
...think this discussion is closed 4 now :-)
