foglertech ft-5
help .. i have a folgertech ft5 with diamond hotend (3 step motor) ... but my extruder motor clicks when i start them and do not turn around .. have checked volt on the steppe drive. and has repetier as firmware
please help?
please help?
M302 S1
to allow cold extrusion, otherwise moves are blocked since extruder might be too cold.
If it doe snot move open eeprom in host/server and check the weights. Might be that your wights are not set or steps per mm are not set in eeprom. Both would also prevent extruder moves. If you never have changed eeprom you can recopy from configuration.h settings with
M502
M500
and try again. Especially if you had a version without that nozzle uploaded before these settings are often not complete.
Simple solution is split it, especially in a script just du
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
G92 E0
G1 E100 F2000
and you have your 800 mm move.
