2 parts on top of each other
I try to print 2 parts on top of each other with 2 extruders. But when i place them and slice using slic3r Prusa Edition as Manager.
I get a warning says "At least one object is outside the printable area" and when i chose to slice anyway.
I find the top part is sliced but starts from Z=zero. Not from the end of the bottom part !!!
How can I make top part related to bottom part to use multi-extruder ?
They both were designed in a different CAD files. both start at Z=0 in the CAD file. Now in Repetier I used 'Move Object' on the left side of the interface by changing X=0 ,Y=-9 and Z=30 to place the second one on the right position.
But when I go to 'Slicer' and slice. I get the error"At least one object is outside the printable area" and then i slice anyway which results slicing both BUT the second part starts from Z=0 not Z=30 !!!
I also tried to group them through 'Settings' in the object information after placing the part in the right position, But when I group them, the second part goes back to Z=0 !!!
