cant seem to connect to repetier with anet a8
hello, i recently bought and built a anet a8 3d printer and i am un able to connect it properly after i resecured the bed and extruder wires, i was only able to get this log
15:41:08.629: start
15:41:09.919: Info:External Reset
15:41:09.932: Info: 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
15:41:09.932: Free RAM:12337
15:43:12.127: Warning: Seems like we missed a ok - continue sending. (19)
as you can see the warning repeated many times, im not entirely sure what that warning means and i dont know how to fix it either
any help is appreciated greatly TIA
  • Since firmware does not respond it seems to hang for some reason. Happens easily if you have I2C devices with wrong device addresses or maybe something else.
    As a first test run config tool with default values and only change board type and retry. If that works add more and more parts of your correct config until you find the param making it hang.
