printing not smooth more like pin heads.
hoendt has a cooler, but no cooler on the part
no errors now so not the USB cable or baud rate
is this caused by not having a part cooler
PLA amzd 1.75 @200c 0.4 head
this is Marvin the paranoid robot in black :>)
So the reason would then be an unsteady flow of filament. Can happen if filament is not hot enough and you are operating at extruders limits. An other thing is extruder not doing equal steps. If you have 16 substeps enabled it needs a certain power to hold these positions or it will move more between full steps and each full step will extruder bigger amounts which are then your blobs. Last possible this is simple overextrusion. Have you calibrated the extruder and found the correct extrusion multiplier for your material? Values of 0.85 are not uncommon.
Did calibrate the extruder but will start there 1st :>)
just so i am consistent , then will try each one, to see what fixes it :>
thanks again
Recoush
