mega 2650 error: temp. raised to slow rise = .043 after 13079 ms
I have order new correct watt heaters, tried different ext. Connection on board, and also voltage tested at all connections from power supply. I cleared the eeprom and reloaded factory firmware as well. Any thoughts why its not heating fast enough? I am running 3950 100k thermistor an 40w ceramic heater on v6 hotend clone. With no fan it will creep to temp after about 5-10 minutes, with full fan it times out everytime.
should be:
#define EXT0_PID_MAX 255
did you measure hotend temperature by external Thermometer or
did you try to push Filament through the Extruder by Hand? as MartinH wrote it also could be reading problem
#define EXT0_PID_INTEGRAL_DRIVE_MAX 140
default is quite limited and that is max. when control takes over. But a temperature curve as I told would you show directly what the error is.
Firmware contains some typically used thermistor curves, so if you selected the right type that is ok.
