Colour Display
as i mounted the Repetier Server Display Close to the Graphic Display i think there is a "cosmetic" need to act.
As i saw Gameduino Display (SPI) implemented which takes Graphics computation load i´m thinking of the
Nextion Displays (UART) ?
Connection should not be a Problem as most common boards have more than one Serial port.
Has somebody tried/made something like this? think it might be Close to PanelDue.
Thanks for any comments
Anyway, is the Gameduino2 working?
May be that would be a solution for a config without controller , just sending commands over Serial.
So i will be complete user defined, nothing for general implementation.
Think I´ll let you know when i get a running system, as you know my main intents are from CNC side ;-)
BTW, got my heaters / Fans controlled over the I2C now , works nice
