Faced with a problem in repetier firmware associated with the operation of fans
Hello! Faced with a problem in repetier firmware associated with the operation of fans. both fans operate with inverted logic, the extruder fan is only activated when the temperature of the nozzle below 50 degrees and the fan blower works 100% when in the off state in repetier host and Vice versa is switched off if the slider is at 100%. please tell me what to fix and where? thanks in advance!
The radds-fd uses a mosfet driver to drive the output mosfet, so needs active low input(inverted)
ramps-fd-v2 uses non inverted signals
make sure you have the right board selected in configuration.
