Endstops are ignored
Hi
I have tried every possible configuration but I can not get the firmware to honor my endstops. They show up as H or L when I press them and check with M119 but the printer will not stop movement when the endstops are hit. Only when homing are the corresponding endstops honored.
Please help.
Here is my endstop section:
Please help.
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 1
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_BACK_ON_HOME 1
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
does not stop while G28 X0 works?
should make sure that G1 would stop in that case, also the move it self should already be prevented being outside of print area.
