Need to solve error message.
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 93218 bytes (36%) of program storage space. Maximum is 253952 bytes.
Global variables use 3870 bytes (47%) of dynamic memory, leaving 4322 bytes for local variables. Maximum is 8192 bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Do not understand first line; have Melzi 2.0_V5 installed.
Also make sure the processor type matches the processor on your melzi board.
The first line is ok, it recognises the melzi as a arduino mega clone
Also, In Pointerface, the x,y and z axis move one way but not back.
So, doesn't mean the correct port is selected?
If you can not move in direction of endstops your endstop are configured wrong and trigger. See M119 output in log.
Maybe its not there since the sketch can't finish loading.
Goto windows deice manager and select ports(com and lpt), in there it should show the port number that the arduino is connected too. set this port number in arduino tools menu,
Device manager shows COM11.
How is it changed in Tools menu?
Also afaik the melzi V2 has a atmega1284p processor, so you need to select this in the arduino tools as well.
Shows only COM10 and atmega1280
