Repetier Host loses focus after stl update
I create an object using Fusion 360.
Export it to an stl file.
Place the stl in repitier host.
Go back to fusion, update the design.
Save stl replacing original.
Return to repitier host which says item has changed, update?
I say yes and am immediately booted back to fusion 360. <<<<< THE PROBLEM!
Go back to repetier and item has been updated.
  • Guess the warning window got focus and when it was removed th etopmost app was fusion as it was previously active.. Will see if I can reproduce it and maybe actively activate host main window after closing.
