Install Z-Probing WITHOUT a Z Max end switch?
I have an Anet A8, the controler board does not have a free connector for a Z-Max switch.
What would would be the proper way to install Repetier Firmware with Z-Probing enabled, without this switch?
I have read as much as I could, and tried, but it seems I am unable to make this work properly, without it. Is there a way to give a Z Max value in a config file, rather than via a switch?
Thanks for your help.
Bernard
Bernard
Bernard
I am following this document (https://www.repetier.com/documentation/repetier-firmware/z-probing/) as well as I can, but it looks like, no matter how I look at it, I need a Z-MAX switch in ADDITION to the probe. Problem is, I have no way to add a sensor, my board has no room for it.
So, questions: Is it possible, YES or NO, to have a proper Z-Probing AND Z-Homing with only a probe?
If yes, what are, in clear language, the steps and settings to have?
Here is my current Configuration.H
Hum, looks like I have problems to attach my file...
Most important is to select same pin for z homing and z probing so firmware can detect this special case.
Then for homing it uses same z probe height for correction, but you might need to set a position to z home since z probes have an offset and need to be above bed. So slect homing sequency with preheat and set preheat temperature to 0. This sequence allows setting a homing position for z homing. Thats all.
But now I have another question: I did a G32 measure on a 5 x 5 matrix, and the measurement goes well, I see differences on Z for each point, inside 1 millimeter, even a bit less.
But If I do G33 L0, I get a list of points, where ALL Z are Z-0.003 !
So what should I do to see the corrections that are going to be applied? Or, to rephrase it, what am I missing?
Thanks!
G33 L0 lists the result of last G33 run. The 5x5 from G32 are ignored here. Only for measuing the tilt from G32 is used to measure G33 since G33 should only fix the remaining unevenness from bed or delta geometry.
