after starting server 0.86 and loging out now wont connect to Host
added the server function and the remote app works great after logout and shutdown
went to Host to run some tests manually and it wont connect to the host with access to com4 port is denied
reset the host app and pressed the reset on the full display?
Any ideas going to try rebooting the computer
Confirmed com 4 is working under devices setting in windows
wish there was a way to copy the api got it working
thanks
recoush
How do i upload repetier firmware arduino ide while i was trying to upload a new config H
received the error messages below?
Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 125270 bytes (49%) of program storage space. Maximum is 253952 bytes.
Global variables use 4444 bytes (54%) of dynamic memory, leaving 3748 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM4": Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
