Autolevel - Z axis crashes into bed!!
I am experimenting with the auto leveling. I am using the latest dev version of the firmware but I have a problem. When I home the z axis it homes all three but the worst of all is it moves down on the z axis until the induction sensor triggers it then moves up as expected and then comes crashing down into the bed!!
Please help as I am at a total loss
set it 3 or 4 to make sure.
Another thing which doesn't seem right is that when I home just Z it still homes all three
Please find my config file below.
Thank you for any help you can give I really want to get this working if possible
homing order , pre raise options, and Z homing locations as below
#define ZHOME_HEAT_HEIGHT 10
The rest looks ok.
So, if you were to go to Z=0 using the manual control panel in RH it would stop at 0? Lets say you do a G1 Z10 and incrementally go from there to 0. with autolevel data cleared it should stop at 0 (not going through the bed) if the stop is seen since you are homing to min.
you also have ui_bed coating set to one,is that correct?
I wasn't sure what to set the bed coating to. I currently have use Buildtak so it isn't very thick. I have also tried setting it to 0 but the same result.
The other suggestion you made works fine. I did the G1 Z10 and I was able to move down to 0 again.
