bowden v6 extrusion calibration
Trying to understand the logistics of calibrating the extruder, found in eeprom setting ext1 and steps was set at 370 changed to 400 for the 0.9 stepper?
turns out was 1.8 same as xy not z was getiing double the length thru the extruder end said send 100mm got 200mm doubt 30 steps =200
Using ramps 1.4 with 8825 drivers and nema 17 0.9 steppers for z axis and Extruder 1 using the plastic lever style bowden with the silicone tubing between them m503 does nothing using repetier for firmware and host
what i did
removed nozzle end from extruder
ran the filirmnt to just be at the end of the nozzle
repetier told to send 100mm
length was 200 mm +- a few
the v6 is about 80mm long even so the filiment was at the end of the nozzle
found the eprom setting was set 370 for EXT1 changed to 400 and said ok
changing the 400 to 200 as the extruder motor is 1.8
what i did
Found the portion of the config H finally and changed it in eprom settings repetier do i have to do a g code save if so how ?
