Laser Add-on
i have an engraving laser and i see that you can enable the laser option on the firmware.
so am i right in thinking i can have a 3d printer that will also engrave?
or is it one or the other.
as i have my laser fitted and connected to digital pin 5 but can't seem to get it to turn on
  • what kind of laser have you got?
    What's  voltage required your laser?
    If you connect the laser to D5, i assume that the laser is powered by a TTL driver so you connect just the signal to RAMPS, right?
    How are you trying to turn on the laser? With a Gcode o manually?
    The laser will powered on ONLY with a G1 gcode command, if you previously set the laser output power...
  • the laser i got from a laser engraving home build kit but dismantled it a few months ago for spare parts . but i kept the laser is this one https://www.banggood.com/445nm-2_3W-2300mW-Blue-Laser-Module-With-Heatsink-For-DIY-Laser-Cutter-Engraver-p-1105563.html?rmmds=search
    i connected the power to a separate power supply as i didn't know the power consumption so i set the voltage to 5v and tried to get the laser on by entering the following G-code
    but all i get is the head moving about and nothing else
    M452
    M3 S255
    G90
    G21
    G0 F3000
    G0 X52.7518 Y8.6326
    G0 F100.000000
    G2 X52.672 Y8.2325 I-1.0434 J0.
    G2 X52.4557 Y7.9195 I-0.8376 J0.3478
    G2 X52.1298 Y7.7216 I-0.6213 J0.6556
    G2 X51.6512 Y7.6411 I-0.4786 J1.3829
    G2 X51.3657 Y7.6631 I0. J1.8644
    G2 X51.1195 Y7.7235 I0.2237 J1.4432
    G2 X50.8842 Y7.8189 I0.9623 J2.7116
    G2 X50.7161 Y7.9082 I0.6725 J1.4692
    G1 X50.7161 Y8.5076
    G1 X50.7394 Y8.5076
    G3 X50.9594 Y8.3361 I1.1796 J1.286
    G3 X51.2011 Y8.2036 I0.9379 J1.4245
    G3 X51.4606 Y8.1184 I0.5829 J1.337
    G3 X51.6885 Y8.0928 I0.2279 J1.0022
    G3 X51.9668 Y8.1273 I-0. J1.1424
    G3 X52.1409 Y8.2065 I-0.1294 J0.515
    G3 X52.2564 Y8.345 I-0.1951 J0.2802
    G3 X52.3041 Y8.5645 I-0.4813 J0.2194
    G3 X52.2771 Y8.7415 I-0.5945 J0.
    G1 X52.2155 Y8.8486
    G3 X52.114 Y8.924 I-0.2482 J-0.2277
    G3 X51.875 Y9.0134 I-0.5973 J-1.2341
    G3 X51.7814 Y9.0376 I-0.897 J-3.2728
    G3 X51.6302 Y9.073 I-2.0733 J-8.5085
    G2 X51.4818 Y9.11 I0.8545 J3.7413
    G2 X51.3574 Y9.1469 I0.7213 J2.6641
    G2 X51.0447 Y9.2978 I0.3911 J1.2099
    G2 X50.87 Y9.4708 I0.3528 J0.5309
    G2 X50.7675 Y9.6986 I0.6556 J0.4319
    G2 X50.7278 Y9.9992 I1.1168 J0.3006
    G2 X50.7447 Y10.1922 I1.1085 J-0.
    G2 X50.7931 Y10.3686 I0.9732 J-0.172
    G2 X50.8769 Y10.5313 I0.8218 J-0.3206
    G2 X50.9959 Y10.6782 I0.787 J-0.5156
    G2 X51.1384 Y10.7937 I0.5692 J-0.5566
    G2 X51.3271 Y10.8885 I0.5658 J-0.8912
    G2 X51.534 Y10.9466 I0.3937 J-1.004
    G2 X51.7794 Y10.968 I0.2455 J-1.3958
    G2 X52.0101 Y10.9507 I-0. J-1.5469
    G2 X52.2505 Y10.897 I-0.2616 J-1.7344
    G2 X52.4845 Y10.8149 I-0.5585 J-1.9672
    G2 X52.6492 Y10.7294 I-0.4441 J-1.0564
    G1 X52.6492 Y10.1583
    G1 X52.6259 Y10.1583
    G3 X52.4473 Y10.2921 I-0.8459 J-0.9432
    G3 X52.2178 Y10.4112 I-0.896 J-1.446
    G3 X51.9724 Y10.4914 I-0.5372 J-1.2275
    G3 X51.7468 Y10.5163 I-0.2256 J-1.0111
    G3 X51.5164 Y10.4846 I0. J-0.8541
    G3 X51.341 Y10.4026 I0.1597 J-0.5701
    G3 X51.2218 Y10.2671 I0.1957 J-0.2924
    G3 X51.1755 Y10.0702 I0.3953 J-0.1969
    G3 X51.2057 Y9.8868 I0.5708 J-0.
    G1 X51.2757 Y9.7748
    G3 X51.3851 Y9.6946 I0.3024 J0.2978
    G3 X51.5929 Y9.6128 I0.5233 J1.0248
    G3 X51.7146 Y9.5804 I1.2571 J4.4718
    G3 X51.8634 Y9.5446 I1.6772 J6.6537
    G2 X52.0145 Y9.5089 I-1.5444 J-6.8674
    G2 X52.1152 Y9.4821 I-0.763 J-3.0741
    G2 X52.3956 Y9.3589 I-0.291 J-1.0428
    G2 X52.5862 Y9.1895 I-0.3965 J-0.6381
    G2 X52.7038 Y8.9626 I-0.5341 J-0.4206
    G2 X52.7518 Y8.6326 I-1.1099 J-0.33
    G1 X52.7518 Y8.6326
    G0 F3000
    G0 X50.2264 Y9.2492
    The laser in your link required 12v as power supply, and eventually a TTL PWM signal for change the power...
    So, maybe 5v are not enough to power it...
    Usually there is a label with the model on the laser, find it so you can know some spec of it...
    Can you also provide us the configuration.h ?
    So we can check that you have correctly set the laser output port...
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       as you expect.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN 9
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN ORIG_FAN_PIN
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN HEATER_2_PIN
    #define FAN_THERMO_THERMISTOR_PIN TEMP_0_PIN
    #define FAN_THERMO_THERMISTOR_TYPE 8
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 400
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 400
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 200
    #define RETRACT_ON_PAUSE 5
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 837
    #define EXT0_HEATER_PIN 10
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 0
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_INTEGRAL_DRIVE_MAX 255
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 10
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN 7
    #define EXT0_DECOUPLE_TEST_PERIOD 600000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 370
    #define EXT1_TEMPSENSOR_TYPE 8
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 1
    #define RETRACTION_LENGTH 5
    #define RETRACTION_LONG_LENGTH 5
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 2
    #define RETRACTION_UNDO_EXTRA_LENGTH 1
    #define FILAMENTCHANGE_Z_ADD  10
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 10
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 1
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 200
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 200
    #define SKIP_M190_IF_WITHIN 5
    #define HEATED_BED_SENSOR_TYPE 3
    #define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 120
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   200
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 100
    #define MAXTEMP 308
    #define MIN_DEFECT_TEMPERATURE -20
    #define MAX_DEFECT_TEMPERATURE 450
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 10
    #define ENDSTOP_Y_BACK_ON_HOME 60
    #define ENDSTOP_Z_BACK_ON_HOME 10
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 1
    #define INVERT_Y_DIR 1
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 270
    #define Z_MAX_LENGTH 190
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 5
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 250
    // ##                           Movement settings                                          ##
    #define BABYSTEP_MULTIPLICATOR 4
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 100
    #define MAX_FEEDRATE_Z 15
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 10
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 80
    #define MAX_JERK 15
    #define MAX_ZJERK 0.1
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 0
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN -1
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define Z_PROBE_Z_OFFSET_MODE 1
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 35
    #define Z_PROBE_SPEED 10
    #define Z_PROBE_XY_SPEED 40
    #define Z_PROBE_SWITCHING_DISTANCE 15
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 1
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 10
    #define Z_PROBE_Y1 10
    #define Z_PROBE_X2 190
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 10
    #define Z_PROBE_Y3 250
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 4
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT ORIG_SDCARDDETECT
    #define SD_EXTENDED_DIR 0 /** Show extended directory including file length. Don't use this with Pronterface! */
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Mike 1"
    #define UI_PRINTER_COMPANY "DMK I.T."
    #define UI_ANIMATION 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN 4
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 80
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MIN_HEATED_BED_TEMP  40
    #define UI_SET_MAX_HEATED_BED_TEMP 125
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   400
    #define UI_SET_EXTRUDER_RETRACT_DISTANCE 5
    #define NUM_MOTOR_DRIVERS 0
        "editMode": 1,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 400,
        "yStepsPerMM": 80,
        "zStepsPerMM": 400,
        "xInvert": "1",
        "xInvertEnable": 0,
        "eepromMode": 1,
        "yInvert": "1",
        "yInvertEnable": "0",
        "zInvert": "0",
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 0,
                "pidDriveMin": 40,
                "pidDriveMax": 255,
                "pidMax": 255,
                "sensorType": 8,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": 10,
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 10,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 837,
                "coolerPin": 7,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 600,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
                "id": 1,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 8,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 3,
        "xMaxEndstop": 1,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 0,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 100,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 15,
        "zHomingSpeed": 10,
        "zTravelAcceleration": 80,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 200,
        "yLength": 270,
        "zLength": 190,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 10,
        "yEndstopBack": 60,
        "zEndstopBack": 10,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 0,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 15,
        "maxZJerk": 0.1,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "0",
        "echoOnExecute": "0",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "1",
        "servo0Pin": -1,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "0",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 200,
        "homeOrder": "HOME_ORDER_XYZ",
        "featureController": 2,
        "uiPrinterName": "Mike 1",
        "uiPrinterCompany": "DMK I.T.",
        "uiPagesDuration": 4000,
        "uiAnimation": "1",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 2,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiPresetBedTempPLA": 80,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 40,
        "uiMaxHeatedBed": 125,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 400,
        "uiExtruderFeedrate": 2,
        "uiExtruderRetractDistance": 5,
        "maxBedTemperature": 200,
        "bedSensorType": 3,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 1,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 120,
        "bedPidDriveMax": 255,
        "bedPidP": 200,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": 4,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 5,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 10,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 100,
        "maxTemp": 308,
        "minDefectTemp": -20,
        "maxDefectTemp": 450,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "0",
        "featureFanControl": "1",
        "fanPin": 9,
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": "HEATER_2_PIN",
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": "TEMP_0_PIN",
        "fanThermoThermistorType": 8,
        "scalePidToMax": "1",
        "zProbePin": "ORIG_Z_MIN_PIN",
        "zProbeBedDistance": 10,
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 35,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 10,
        "zProbeXYSpeed": 40,
        "zProbeHeight": 1,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 10,
        "zProbeY1": 10,
        "zProbeX2": 190,
        "zProbeY2": 10,
        "zProbeX3": 10,
        "zProbeY3": 250,
        "zProbeSwitchingDistance": 15,
        "zProbeRepetitions": 1,
        "sdSupport": "0",
        "sdCardDetectPin": "ORIG_SDCARDDETECT",
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": "ORIG_FAN_PIN",
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 4,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": -1,
        "mixingExtruder": "0",
        "decouplingTestMaxHoldVariance": 200,
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 5,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "1",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 5,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 250,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "1",
        "retractionLength": 5,
        "retractionLongLength": 5,
        "retractionSpeed": 40,
        "retractionZLift": 2,
        "retractionUndoExtraLength": 1,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 10,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 1,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "preventZDisableOnStepperTimeout": "1",
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 4,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "maxHalfstepInterval": 1999,
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "uiHeadline": "",
        "bedPreheat": 55,
        "zProbeEveryPoint": "",
        "jamMethod": 1,
        "laserWarmupTime": 0,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 1,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 10,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 2,
        "version": 92.9,
        "primaryPortName": ""
    You have to setup your firmware to enable the laser....
    Load the configuration.h in the online configuration tool and enable it, and choose the output port...
    In your config.h the laser feature is disabled...
  • edited August 2017
    #define SUPPORT_LASER 1
    #define LASER_PIN 5
    also, the laser kicked up when i hit it with 12v.
    so how do i tell the software i want to use the 3d printer then after engraving the model with the laser. can this be done in one program?
  • According to the
    http://reprap.org/mediawiki/index.php?title=G-code&diff=177550&oldid=177545
    M450 tells you the mode and
    M451, M452, M453 selects the different modes.
     I just have a FDM printer so I cannot verify this.
  • If you have a laser engraver, then the main task - do not hurt when installing!
    It should be noted a number of features that must be taken into account when installing an independent laser engraver:
    After connecting the power supply, voltage regulator and grounding, make a test run of the equipment.
    Before first use, be sure to align the optical system.
    Then, you need to connect a laser engraver to the computer and install the software (drivers), and again do a couple of trial runs on different materials. Of course, you need to understand that the compatibility of software with different engravers is also important. I found here https://www.bestadvisor.com/laser-engraver a good table with information for different types of engravers. That's it depends on these drivers very much. For example, programs that convert raster images to vector, and vector - to gcode. For example, free distributed programs InkScape, SketchUp, GBRLcontroller, Repetierhost, Cura.
  • Hey
    I have the same Laser unit, that is powered by 12v and used TTL/PWM to control the power.
    Was reading previous posts but still a bit unsure on the connections.
    I searched for documentation but can't find much specially on the connections.
    To where should the TTL/PWM be connected? So something like the extruder fan pin?
    Than in a printer is a PWM output right?
  • I’ve been looking for a good casino for a long time and finally found https://playbestgameswelcome.com the first time I went to the casino’s website and won a decent amount of money by playing, I was pleasantly surprised, put to a conclusion, paid quickly and without problems, I decided that it was just very lucky and for a long time hesitated to play yet, but after some time decided to try playing again and won a good amount again.
