3D Printer has stopped running the desired G-Code
Just recently, my 3D Printer has oddly stopped executing the desired G-Code, despite, according to the Repetier-Host, is printing.
On the Host, it surprisingly goes through the print, except a lot faster than how you normally would print.
While on the printer, nothing is happening.
Details:
OS: macOS Sierra
Baud Rate: 234000
Stop Bits: 1
Parity: None
Transfer Protocol: Autodetect
Receive Cache Size: 63s
Timeout: 40s
Thanks, and I appreciate your help.
Details:
OS: macOS Sierra
Baud Rate: 234000
Stop Bits: 1
Parity: None
Timeout: 40s
Where do I start?
I tried re-installing repeater host on my Mac and also re-installed the fo=Irmware on my da Vinci 1.0a - made no difference at all.
Thanks so much in advanced.
< 2:06:19 PM: Unknown command:N85 M107
it then shows x3 quite a lot
then this appears:
a bunch of x3 again then ends with:
< 2:08:00 PM: Unknown command:N5927 M107
I still can't decipher what the error is.
I really appreciate your help.
Thanks.
x3 is nothing that should be shown. What version are you using? You could search "x3" and delete the line most probably. I guess it is a forgotten debug message somewhere.
What you search is a line starting with Error: at the time printing stops and commands run faster through.
This is the end of the codes...
I cannot see any obvious error on any line.
Your thoughts are greatly appreciated.
Thanks.
The X, Y, and Z values aren't changing. Only the "E" value.
I tried printing from SD card with same results.
Thanks for your thoughts and help!
