Transfer printer settnings from Cura to Repetier?
I have a borlee mini 3d printer, and it came with instructions on the printer settnings for Cura, but when I got repetier host, I had to fill in settnings I had NO IDEA of. Im hoping that I can transfer the settnings from cura to repetier and that that might do it.
  • You can not copy settings, sorry. Depending on the slicer you use names may vary a bit but it the most important variables should be quite clear. Speeds are most important and the width on different parts is also important, the rest is more or less to solve some minor problems and personal likings.
