Repetier Host V1.06 Motor extruding backwards
Currently using Host 1.06
When using manual control to load and unload the filament, the motor spins in the opposite direction. When trying to run program the motor also spins in the opposite direction. I tried using a different motor and still saw the same problem.
Or in your firmware configuration choose to invert extruder direction. There is a define that controls this, but depends on used firmware.
