Kossel Linear Plus Dimension error
Hello.
I have Anycubic Kossel Linear Plus. Week ago i switched to Repetier. After that, i calibrated whole table to be flat using Escher3 wizard. Just perfect with default Rod Length 271.5. (Real ~ 267.8. But with this value, i have problem with opposite points. On X, Y, Z table = 0mm, on XY, YZ, ZX = ~-1.5-2mm)
But my prints are smaller, than it must be.I printed this: https://www.thingiverse.com/thing:1274733. It must be 75mm, but i got ~74mm.
From this point, things became weird. If i decrease rod length to suggested, i have problem with opposite points. If i calibrate table to be flat, my prints are smaller.
What should i do with this? Any advices?
The only way (as far as i know) to rise opposite poits is to increase the rod length.
That is really strange.
