Two endstop, one signal
I need to use 2 Z endstops at the same time. I made printer with possibility of mounting Laser on it along with extruder. Problem is when I want use Laser i need to use other Z stop that is mount on laser. I don't want to change cables every time and opening electronic case. I would like to use X max as a second Z endstop working along with first Z endstop.
  • We have no software solution for this. But if you put them in parallel either of them would trigger the endstop. Just make sure the wrong one can not trigger if laser is mounted.
    Alternatively modify the check endstop method. Since dev version has a laser mode you can switch pin number depending on current mode.
