Working logic of the Repetier-Firmware
How can I learn. The working logic of the Repetier-Firmware ? Video, Shema etc.
  • Read the docs online and in doc folder on github. Gives some help and then just read the sources. It is quite easy to understand as the aspects are clearly separated and control flow is simple. Read command -> execute command -> run periodic actions is the main loop.
