Impossible to upload firmare with FEATURE_Z_PROBE = 1 ?
I use a Pibot V2.0 board on my 3D printer, when i try to activate Z probe leveling in firmware (0.92.9), i have an error at the end of firmware upload. Impossible to upload the firmware with FEATURE_Z_PROBE = 1
I don't understand what is the problem. I try to change te pin assignement of Z_probe (PiBot_Z_PROBE_PIN or ORIG_Z_MIN_PIN) without solve the problem.
I use Arduino 1.6.5 and the error is :
avrdude: verification error, first mismatch at byte 0x0000
         0x0f != 0x0c
avrdude: verification error; content mismatch
Configuration.h is:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 316
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#define FAN_THERMO_MIN_PWM 0
#undef Z_MIN_PIN
#define Z_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Y_MAX_PIN
#define Y_MAX_PIN -1
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define BLUETOOTH_BAUD  115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 50
#define YAXIS_STEPS_PER_MM 50
#define ZAXIS_STEPS_PER_MM 640
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 5
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 69.1
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 150
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 255
#define EXT0_PID_INTEGRAL_DRIVE_MIN 0
#define EXT0_PID_PGAIN_OR_DEAD_TIME 20
#define EXT0_PID_I 0.6
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 69.1
#define EXT1_TEMPSENSOR_TYPE 8
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 1
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 1
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 150
#define EXT1_HEAT_MANAGER 1
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_INTEGRAL_DRIVE_MAX 255
#define EXT1_PID_INTEGRAL_DRIVE_MIN 0
#define EXT1_PID_PGAIN_OR_DEAD_TIME 20
#define EXT1_PID_I 0.6
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 5
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_SPEED 40
#define FILAMENTCHANGE_Z_ADD  2
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 0
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   35
#define HEATED_BED_PID_IGAIN   0.5
#define HEATED_BED_PID_DGAIN 200
#define HEATED_BED_DECOUPLE_TEST_PERIOD 10000
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MIN false
#define ENDSTOP_PULLUP_Y_MIN false
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
#define ENDSTOP_Z_BACK_ON_HOME 1
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 300
#define Y_MAX_LENGTH 175
#define Z_MAX_LENGTH 323
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define STEPPER_INACTIVE_TIME 60L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 400
#define MAX_FEEDRATE_Y 400
#define MAX_FEEDRATE_Z 40
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 20
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0.1
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 5
#define DIRECTION_DELAY 5
#define ALLOW_QUADSTEPPING 0
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 4000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 4000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 4000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 4000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 300
#define MAX_JERK 40
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 500000
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  -1
#define SERVO1_NEUTRAL_POS  -1
#define SERVO2_NEUTRAL_POS  -1
#define SERVO3_NEUTRAL_POS  -1
#define UI_SERVO_CONTROL 0
#define FAN_KICKSTART_TIME  200
        #define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET -5
#define Z_PROBE_Y_OFFSET 1
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 300
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 10
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT ORIG_SDCARDDETECT
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 8
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "Perfect 3D Printer"
#define UI_PRINTER_COMPANY "VR Electronique"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 20
#define UI_KEY_FIRST_REPEAT 300
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_START_SCREEN_DELAY 3000
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 100
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   230
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 5
#define NUM_MOTOR_DRIVERS 0
Could you help me ?
  • avrdude: verification error, first mismatch at byte 0x0000
             0x0f != 0x0c
    that comes from the uploader which does not care about the code it self. It verifies result at the end to check if upload was working and it found a difference in the first byte already. So this is more a problem that flashing did not succeed as expected. Normally you just retry and it should then work or you get a different error position. If it is always byte 0 it should happen with any program you upload.
  • I'm Ok with you but if i disable z probe (FEATURE_Z_PROBE = 0) upload firmware works well at the first time.
    I don't understand the relation between FEATURE_Z_PROBE = 1 and error at the end of upload process.
    It is always byte 0 in error !
  • That is in deed strange. Try enabling/disabling some other functions and see if it then works. At least with the !!! bug in uploader it works often as it changes code positions.
  • Hello,
    If i disable the SD Card support, the firmware with  FEATURE_Z_PROBE = 1 can be uploaded successfull !
    Is it a memory space problem ? With SD Card disable an Z_Probe enable the occuped memory is 43%. But if i enable both functions, the occuped memory is 52% and upload firmware not works.
    Where is the problem ? In USB bootloader in Pibot card ? What bootloader is recommanded with repetier firmware ?
  • So pibot has a mega2560 but more then 128kb is a problem? At least the original mega2560 bootloader can do that without problems. But we do not write bootloaders, these are part of board and come preinstalled and setting them up is not as easy as uploading.
  • Hello,
    I solved the problem by changing the bootloader by "stk500boot_v2_mega2560.hex", the original bootloader of Arduino.
    I use an Atmel JTAGICE MKII probe to program the 2560 processor.
    I no longer have a download error with SD Card Enable and E_probe enable.
    The bootloader loaded by Pibot is too old (ATmegaBOOT_168_mega2560.hex) and not support correctly a firmware more than 128Kb.
  • Thanks for the information and glad you have enough knowledge to update a bootloader to verify this. Hope they have meanwhile upgraded bootloader.
