Z-axis off.. printing stringy
Anyone have any ideas? it looks like there is a setting out of wack for the z-axis. I was printing layer 35 of 125 when I stopped the print. I just upgraded my firmware and host today. I did use the firmware configurator. This is my first print since solving two other issues. Prior to the upgrade everything worked just fine. Not sure where to start so let me know.
Normally you can set z steps per mm in eeprom editor in host. Which might also the reason changing it in firmware doe snot help. It uses eeprom values.
