Server stops running when logged in with mobile
i am new to this server. I flashed an raspberry Pi 3 with the image and connected 1 printer and 1 webcam. All runs fine if controlled via repetier host or chrome on pc. But if someone connects to the webinterface with an smartphone (android or iphone) the site loads and the pop up "connection lost" shows up. The Pi doesnt recover alone. Running prints are stopping. The only way to get the server back running is to power off the device.
Is there anything i am missing?
Maybe you could login via pc with ssh and run "htop" ot "top" to see if a process start getting all cpu time or memory is running out.
I personally do not have this problem and can see everything.
BTW: Is this a recent smartphone or an old one? We use modern HTML 5 with javascript so old smartphones may add problems if browser is old.
The phones are decent new. Samsung Galaxy S7 and the newest Iphone what ever
so i tested again. Now with no printjob running i was able to navigate a little trough the frontend. But at some point i clicked on the Home-button (the house) and i lost connection on the mobiledevice, on repetierhost and the ssh terminal.
Here is the last screen from the terminal
i know the description is awful. If the error is on pc i would record an screencast
Was ssh over ethernet or also wifi? It might be that just wifi stopped working. Also question would would be why this happens if you use a mobile and not from pc.
I am not an linux expert, so its kind of a riddle for me. I used the stock image. Didnt do anything with the host system.
