Prusa i3 won't connect
My Prusa i3 won't connect to the Repetier server using a com port and will only weakly connect using the virtual ports. Either way, it is unable to print. I've tried using different computers and USB cables but neither have worked. I am currently rechecking that the printer is built correctly but so far I'm still unable to connect to the Repetier server or to print. How should I troubleshoot?
Either it connects or not. If not make sure you have a firmware on your prusa, baud rate is set correctly and right port selected.
Once connected check log for errors and messages and report what you see.
But, because there is a but, it was not easy from the beginning.
I changed protocol for Marlin COM for COM4 and speed autoconfig.
And setup was frozen.
Then I abort and changed only the speed to 115200. And it worked very nice.
Thank you very much again because you saved my day. I want to tell you that I am using the Repetier Server Pro for a half a year but this time I did not have inspiration .
