BabyStep gcode (m290) support
Not sure if it is available...but it would be really helpfull to have a gcode for babystepping. Recent dev branch of Slic3r supports custom-gcode for filaments. That sounds really great because PLA & ABS needs different "leveling" between (heated) bet and nozzle.
Unfortunately Repetier does not support M290...
Is there any plan to include it in later versions?
Regards,
DeJe
Regards,
DeJe
We had so far no gcode for babysteps as you want them executed fast and from a host this makes no sense with 16-20 moves delay until execution. For misuing the z calibration in such a way a command would make sense, also it feels wrong and should better be replaces by a G92 after homing to correct the offset. Hope to remember to check how it works and add it. Should be easy with having babysteps in general already available.
