Changing G code temperatures
So, let's say I have brand X PLA and brand Y ABS sitting around, and there's a model that I print often. With the model's G code already in the server, there is no way to change the printing temperatures for the bed/extruder without doing so manually through the printer's physical interface. Since the software already goes through the G code, uses the preset temperatures to generate estimated print times, and already has the ability to store the printing temperatures for multiple filaments, I suggest that there be an option when starting a print to choose a filament to print with that would change the temperatures in the G code to what they need to be for that filament. Just an idea I thought of that I know I would use often! <span>
</span>
What would be a good addition is to add a info for hottest extruder/bed temperature so you can at least see afterwards for which temperatures it was sliced.
