How to enable x,y,z max endstop?
Printer HE3D Prusa ei3.
So, have troubles with my x,y,z MAX endstops. They don't work when i press them. I ask seller to send me firmware, and found, that in configuration.h in endstop section i got this values:
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
So, what I need to change to enable max endstops?
And what I need to change in my pins.h? And where i can get info what model my motherboard?
  • Disable the max software endstops, enable the hardware endstops
    #define MAX_HARDWARE_ENDSTOP_Z false -> true
    Also make sure you have them connected to the official max endstop pins on board or you also need to define the pins.
    If you want to home to max change homing direction to 1 from -1
    M119 should show if they are present and work.
