Jam detection help please
Is there a step-by-step guide to configuring jam detection on Repetier, or does anyone have any suggestions to help, please?
I am using Repetier Host v2.0.0, Server v0.80.3 and firmware v0.92.9 and have added a Hall effect filament jam detector that pulses onto pin D40.
I have configured it in firmware using:
  • Extruder stepper:           255 steps/mm
  • Jam_Steps:                   1366 steps (the detector gives 1 step every 5.357mm so I multiplied the steps/mm of the extruder by 5.357)
  • Jam_Slowdown_Steps: 1500
  • Jam_Slowdown_To:       70%
  • Jam_Error_Steps:          2000
  • Jam_Min_Steps:            50
When I test the extruder by extruding 100mm it does this fine but the jam detector reports that it is slipping and eventually reports a jam when I try to print
Am I doing something obviously wrong? Is there any way to display the pulses or steps that the jam detector is reporting?
And as a secondary point, is there an optimum length per pulse for the detector? I am able to add more magnets to increase the pulses per turn so can easily amend the current setting.
Thanks.
Richard
  • I think I've answered some of my questions. I found the M602 command and have been using that to debug and to see the pulses and am now tuning it to work effectively.
    I'd still like to know if there is an optimum pulse / mm or pulse / extruder steps setting or design parameter so that I can optimise that.
    Richard
  • Optimum would be a Jam_Slowdown_Steps bigger than anything you experience in normal working situations. WIth debug you can already see what it really measures then add sone 30% on it as a start. Error should be again 30-50% on top I'd say. If you have a real error you will trigger any value anyway but on the other side you also want to trigger early.
    Thank you for your response, Repetier!
    To check my understanding, please. If the highest steps / pulse I see in normal use is, say, 1000 then I should set Jam_Slowdown_Steps to 1,300 and Jam_Error_Steps to approx 1,700 - 2,000
    Am I understanding correctly?
    Thanks.
    Richard
  • Oh, and one further question - is it possible to edit the Jam settings anywhere other than by recompiling the firmware and uploading it? Is it available in the EEPROM or elsewhere accessible from the Repetier Server or Host?
    I've looked in both but not been able to find it yet.
    Thanks.
    Richard
  • It is fixed in firmware, no eeprom. But you can change it by gcode:
    - M604 X<slowdownSteps> Y<errorSteps> Z<slowdownTo> T<extruderId> - Set jam detection values on a per extruder basis. If not set it uses defaults from Configuration.h
    And yes, you understood me correctly regarding steps.
  • Thanks again - much appreciated! I'll be able to play with the values and then lock them in to the firmware when I've goyt them sorted.
    Richard
  • Allow me to reuse this topic, I enabled jam debug with M602 S1 P1 but there's no output on console and many communication timeouts.
    Comm errors stops when I disable debug (M602 S0 P1).
    I'm using 1.0.4dev
    14:04:41.744: N5197 M602 S1 P1
    14:04:41.903: ok 5189
    14:04:41.904: N5198 G1 X155.093 Y125.838 E54.1681
    14:04:45.185: ok 5190
    14:04:45.271: ok 5191
    14:04:45.271: N5199 M117 ETA 14:34:10 day 7
    14:04:48.744: ok 5192
    14:04:48.744: N5200 G1 X199.356 Y170.101 E56.6665
    14:04:48.949: ok 5193
    14:04:48.949: N5201 G1 X199.370 Y169.539 E56.6890
    14:04:48.954: ok 5194
    14:04:48.954: N5202 G1 X199.360 Y169.426 E56.6935
    14:04:52.427: ok 5195
    14:04:52.427: N5203 G1 X155.093 Y125.159 E59.1921
    14:04:52.427: N5204 G1 X155.093 Y124.480 E59.2192
    14:04:52.513: ok 5196
    14:04:52.513: N5205 G1 X199.293 Y168.680 E61.7140
    14:04:56.228: ok 5197
    14:04:56.228: N5206 M117 ETE 00:29:15
    14:05:26.376: busy:processing (15)
    14:05:27.597: Jam debugging:1
    14:05:27.601: Info:Marked all extruders as unjammed.
    14:05:27.601: Jam control disabled:1
    14:05:27.700: ok 5198
    14:05:27.700: ok 5199
    14:05:27.701: N5207 M117 ETA 14:34:18 day 7
    14:05:27.802: ok 5200
    14:05:27.802: ok 5201
    14:05:27.802: ok 5202
    14:05:27.802: ok 5203
    14:05:27.802: ok 5204
    14:05:27.803: N5208 G1 X199.226 Y167.934 E61.7439
    14:05:27.803: N5209 G1 X155.093 Y123.802 E64.2350
    14:05:27.803: N5210 G1 X155.093 Y123.123 E64.2620
    14:05:27.803: N5211 G1 X199.159 Y167.188 E66.7493
    14:05:27.804: N5212 G1 X199.093 Y166.461 E66.7784
    14:05:27.805: ok 5205
    14:05:27.806: ok 5206
    14:05:27.806: N5213 G1 X199.089 Y166.439 E66.7793
    14:05:27.806: N5214 G1 X155.093 Y122.444 E69.2626
    14:05:27.904: ok 5207
    14:05:27.904: N5215 G1 X155.093 Y121.765 E69.2897
    14:05:28.011: ok 5208
    14:05:28.011: Error:Wrong checksum
    14:05:28.011: N5216 G1 X198.911 Y165.583 E71.7629
    14:05:28.015: ok 5209
    14:05:28.015: ok 5210
    14:05:28.015: ok 5211
    14:05:28.015: ok 5212
    14:05:28.016: ok 5213
    14:05:28.016: N5217 M532 X5.3887 L4
    14:05:28.016: N5218 G1 X198.733 Y164.726 E71.7979
    14:05:28.016: N5219 G1 X155.093 Y121.086 E74.2611
    14:05:28.016: N5220 G1 X155.093 Y120.407 E74.2882
    14:05:28.017: N5221 G1 X198.555 Y163.869 E76.7413
    14:05:28.018: Error:Wrong checksum
    14:05:28.019: Resend:5214
    14:05:28.030: ok
    14:05:28.030: Error:Wrong checksum
    14:05:28.030: Resend: N5214 G1 X155.093 Y122.444 E69.2626
    14:05:28.030: Resend: N5215 G1 X155.093 Y121.765 E69.2897
    14:05:28.039: ok 5214
    14:05:28.039: ok 5215
    14:05:28.039: Resend: N5216 G1 X198.911 Y165.583 E71.7629
    14:05:28.040: Resend: N5217 M532 X5.3887 L4
    14:05:28.043: ok 5216
    14:05:28.043: Resend: N5218 G1 X198.733 Y164.726 E71.7979
    14:05:28.047: ok 5217
    14:05:28.047: ok 5218
    14:05:28.048: Resend: N5219 G1 X155.093 Y121.086 E74.2611
    14:05:28.048: Resend: N5220 G1 X155.093 Y120.407 E74.2882
    14:05:32.054: Warning: Communication timeout - resetting communication buffer.
    14:05:32.054: Connection status: Buffered:38, Manual Commands: 0, Job Commands: 5000
    14:05:32.054: Buffer used:38 Enforced free byte:19 lines stored:2
    14:05:32.054: Resend: N5221 G1 X198.555 Y163.869 E76.7413
    14:05:32.055: N5222 G1 X198.465 Y163.435 E76.7590
    14:05:35.625: ok 5219
    14:05:35.695: ok 5220
    14:05:35.695: N5223 M117 ETE 00:28:40
    14:05:35.711: ok 5221
    14:05:35.711: N5224 G1 X198.299 Y162.934 E76.7801
    14:05:35.712: N5225 G1 X155.093 Y119.729 E79.2188
    14:05:39.717: Warning: Communication timeout - resetting communication buffer.
    14:05:39.717: Connection status: Buffered:38, Manual Commands: 0, Job Commands: 5000
    14:05:39.717: Buffer used:38 Enforced free byte:19 lines stored:2
    14:05:39.717: N5226 G1 X155.093 Y119.050 E79.2459
    14:05:39.717: N5227 G1 X197.962 Y161.919 E81.6656
    14:05:43.560: ok 5222
    14:05:43.621: ok 5223
    14:05:43.621: N5228 M117 ETA 14:34:07 day 7
    14:05:43.723: ok 5224
    14:05:43.724: N5229 G1 X197.626 Y160.904 E81.7082
    14:05:43.724: N5230 G1 X155.744 Y119.021 E84.0723
    14:05:47.727: Warning: Communication timeout - resetting communication buffer.
    14:05:47.727: Connection status: Buffered:38, Manual Commands: 0, Job Commands: 5000
    14:05:47.727: Buffer used:38 Enforced free byte:19 lines stored:2
  • Do you have a sensor with changing signals to measure distances? This debugging is only for that type of jam detector.
  • I made optical jam detectors so yes, signal changes but I have 3 extruders so 3 jam detectors.
    Does debug works in this case ? Is there a way to print current state of all jam pins ?
  • All have different pins, so no problem. Output is only written on signal change so it is for the active one that moved.
    I think correct command to debug is
    M602 S1 P0
  • Thanks, I'll try this ... I thought printer fail if Jam detection isn't disabled but it make sense that nothing happens when disabled.
  • You're right, Jam detection need to be enabled for debug to work.
    Thanks for help.
