Configuration Dimensions
Please verify what the following dimensions are:
Carriage_Horizontal_Offset (Does this value really need to be entered?)
Delta_Max_Radius (Is it horizontal distance from the rod-carriage connection to rod-effector connection?)
Rod_Radius (Is it horizontal distance from the rod-carriage connection to rod-effector connection?)
Printer_Radius (Is it only the radius of the print plate?)
  • These are no host settings!
    #if !defined(ROD_RADIUS) && DRIVE_SYSTEM == DELTA
    #define ROD_RADIUS (PRINTER_RADIUS-END_EFFECTOR_HORIZONTAL_OFFSET-CARRIAGE_HORIZONTAL_OFFSET)
    So if you define ROD_RADIUS the offset is not needed.
    DELTA_MAX_RADIUS is the radius your effector should not leave for safety etc. has no influence on computations it self.
    PRINTER_RADIUS is just a helper to calculate ROD_RADIUS if not set.
