autoleveled delta is always .5mm high on -x
So I have a nice and standard delta (Anycubic Kossel) with a bltouch. I run the autoleveling (G32 S2), no distortion correction, and as result the print is about .5 over the bed on the -x side and scraped into the bed on +x. I tried raising the -x side, but the result is the same (so the autoleveling is working, it's just not giving me the result I want...
I think I'm doing something wrong here, I just have no idea what.
Version: the dev from the configurator
Configuration and EEPROM: https://gist.github.com/HenryLoenwind/3eb3f122fc1e24754a82b7ee1038348b
Endstop offsets from G132
The last G32 run:
4:41:09.311: Z-probe:7.505 X:-60.00 Y:-16.00
4:41:15.604: Z-probe:7.573 X:-60.00 Y:-0.40
4:41:21.921: Z-probe:6.268 X:-60.00 Y:15.20
4:41:28.256: Z-probe:7.868 X:-60.00 Y:30.81
4:41:34.599: Z-probe:7.965 X:-60.00 Y:46.41
4:41:40.971: Z-probe:8.057 X:-60.00 Y:62.00
4:41:47.682: Z-probe:7.135 X:-36.00 Y:-16.00
4:41:53.935: Z-probe:7.253 X:-36.00 Y:-0.40
4:42:00.214: Z-probe:7.413 X:-36.00 Y:15.20
4:42:06.501: Z-probe:7.520 X:-36.00 Y:30.81
4:42:12.807: Z-probe:7.675 X:-36.00 Y:46.41
4:42:19.128: Z-probe:7.795 X:-36.00 Y:62.00
4:42:25.805: Z-probe:6.808 X:-12.00 Y:-16.00
4:42:32.021: Z-probe:6.960 X:-12.00 Y:-0.40
4:42:38.257: Z-probe:7.115 X:-12.00 Y:15.20
4:42:44.519: Z-probe:7.313 X:-12.00 Y:30.81
4:42:50.798: Z-probe:7.470 X:-12.00 Y:46.41
4:42:57.095: Z-probe:7.625 X:-12.00 Y:62.00
4:43:03.743: Z-probe:6.543 X:12.00 Y:-16.00
4:43:09.915: Z-probe:6.655 X:12.00 Y:-0.40
4:43:16.113: Z-probe:2.592 X:12.00 Y:15.20
4:43:22.331: Z-probe:7.003 X:12.00 Y:30.81
4:43:28.571: Z-probe:7.192 X:12.00 Y:46.41
4:43:34.835: Z-probe:7.385 X:12.00 Y:62.00
4:43:41.417: Z-probe:6.035 X:36.00 Y:-16.00
4:43:47.543: Z-probe:6.268 X:36.00 Y:-0.40
4:43:53.694: Z-probe:6.480 X:36.00 Y:15.20
4:43:59.871: Z-probe:6.678 X:36.00 Y:30.81
4:44:05.191: Z-probe:5.420 X:36.00 Y:46.41
4:44:11.418: Z-probe:7.095 X:36.00 Y:62.00
4:44:17.933: Z-probe:5.542 X:60.00 Y:-16.00
4:44:23.991: Z-probe:5.788 X:60.00 Y:-0.40
4:44:30.094: Z-probe:6.060 X:60.00 Y:15.20
4:44:36.219: Z-probe:6.280 X:60.00 Y:30.81
4:44:42.374: Z-probe:6.540 X:60.00 Y:46.41
4:44:47.685: Z-probe:5.320 X:60.00 Y:62.00
4:44:47.687: plane: a = -0.0149 b = 0.0093 c = 6.5683
4:44:47.698: Transformation matrix: 0.999890 0.000000 0.014858 0.000139 0.999956 -0.009334 -0.014857 0.009335 0.999846
4:44:47.698: Printer height:296.80
4:44:47.698: CurrentZ:6.57 atZ:7.10
4:44:47.713: Info:Autoleveling enabled
This was done with the severely raised bed as described above. And this was the run before that, only slightly raised bed:
4:29:53.289: X:0.00 Y:0.00 Z:297.400 E:224.9375
4:30:05.298: Z-probe:7.583 X:-60.00 Y:-16.00
4:30:11.601: Z-probe:7.653 X:-60.00 Y:-0.40
4:30:17.932: Z-probe:7.820 X:-60.00 Y:15.20
4:30:24.282: Z-probe:7.978 X:-60.00 Y:30.81
4:30:30.639: Z-probe:8.077 X:-60.00 Y:46.41
4:30:37.013: Z-probe:8.200 X:-60.00 Y:62.00
4:30:43.750: Z-probe:7.253 X:-36.00 Y:-16.00
4:30:50.023: Z-probe:7.398 X:-36.00 Y:-0.40
4:30:56.318: Z-probe:7.538 X:-36.00 Y:15.20
4:31:02.641: Z-probe:7.785 X:-36.00 Y:30.81
4:31:08.981: Z-probe:7.938 X:-36.00 Y:46.41
4:31:15.338: Z-probe:8.097 X:-36.00 Y:62.00
4:31:22.049: Z-probe:7.060 X:-12.00 Y:-16.00
4:31:28.303: Z-probe:7.225 X:-12.00 Y:-0.40
4:31:34.581: Z-probe:7.415 X:-12.00 Y:15.20
4:31:40.872: Z-probe:6.108 X:-12.00 Y:30.81
4:31:47.201: Z-probe:7.813 X:-12.00 Y:46.41
4:31:53.543: Z-probe:7.963 X:-12.00 Y:62.00
4:32:00.222: Z-probe:6.798 X:12.00 Y:-16.00
4:32:06.443: Z-probe:6.978 X:12.00 Y:-0.40
4:32:12.696: Z-probe:7.190 X:12.00 Y:15.20
4:32:18.971: Z-probe:7.445 X:12.00 Y:30.81
4:32:25.266: Z-probe:7.630 X:12.00 Y:46.41
4:32:31.596: Z-probe:7.825 X:12.00 Y:62.00
4:32:38.225: Z-probe:6.438 X:36.00 Y:-16.00
4:32:44.399: Z-probe:6.653 X:36.00 Y:-0.40
4:32:50.614: Z-probe:6.925 X:36.00 Y:15.20
4:32:56.861: Z-probe:7.205 X:36.00 Y:30.81
4:33:03.135: Z-probe:7.420 X:36.00 Y:46.41
4:33:09.438: Z-probe:7.653 X:36.00 Y:62.00
4:33:16.008: Z-probe:5.940 X:60.00 Y:-16.00
4:33:22.135: Z-probe:6.285 X:60.00 Y:-0.40
4:33:28.316: Z-probe:6.650 X:60.00 Y:15.20
4:33:34.524: Z-probe:6.913 X:60.00 Y:30.81
4:33:40.755: Z-probe:7.112 X:60.00 Y:46.41
4:33:47.025: Z-probe:7.403 X:60.00 Y:62.00
4:33:47.026: plane: a = -0.0091 b = 0.0127 c = 7.0232
4:33:47.037: Transformation matrix: 0.999958 0.000000 0.009107 0.000116 0.999919 -0.012710 -0.009106 0.012710 0.999878
4:33:47.037: Printer height:297.33
4:33:47.038: CurrentZ:7.02 atZ:7.10
4:33:47.053: Info:Autoleveling enabled
(I'm starting to hate autoleveling. There I have my P802, which I manually leveled 2 months(!) ago, and then there are the 2 printers that aren't that stable and need autoleveling...)
