Motor mirroring - 'DIOEX10_ENABLE2_PIN_WPORT' (compile error)
I tried to mirror extruder0 and extruder1 to my X-Axis and get the following error while compiling:
"exit status 1
'DIOEX10_ENABLE2_PIN_WPORT' was not declared in this scope"
What is wrong here?
The X-Axis is only used in this test setup.
Main goal here is to use an additional stepper for an active mixing chamber that is mirrored to both extruder0 and extruder1.
So that the mixing Extruder is only turning while extruding and always at the same speed.
