How to calibrate the z axis ??
  • Hi, I need to know how to calibrate the z axis, I need to move the axis at a certain distance and then tell the machine that it is the zero point. ..
  • If you have a mechanical Z endstop switch, then it is  a matter of adjusting the switch to get the correct Z0 position.
    If you have a Z probe the the Z0 position is set by the Z_probe_height setting probe setup
