3 point Z Probe issue
Hi
Looking for some help.
I have an HE3D, having got the correct firmware loaded and everything moving in the correct direction, when I go to Print and the Auto level start to do it thing the Z-Probe hangs over the bed on the righthand side see video link
https://youtu.be/d3VC0EVgGpE
I have tried editing the below setting mainly changing the X2 and X3 setting from 180 to 100 / 150 and re uploading the firmware then comiting the setting to the rom but it does not change anything still over hangs the bed on the second point measure.
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 0
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 180
any help greatly received.
thanks
  • Have you checked coordinates in eeprom?
    Also consider that the z probe offset is also applied to your coordinates!
