Print fail detector
Just found the zyyx+ printer and the one thing that caught my attention was the print fail sensor. It appears to be a mechanical switch of sorts mounted to the head just above the nozzle by a mm or 2.
Has anyone tried to do this with repetier? Seems like we should be able to use M226 to read when that pin goes high. Or use the jam detection which is usually used for out of filament sensors to trigger as well for this switch.
Any thoughts?
Any thoughts?
