Max home direction
So I've had to move my endstop switch to the other side of the X axis because of a part cooler. When I invert the X direction and home direction my printer will print everything as a mirrored image making it impossible to read text. This can be fixed by mirroring the objects in the slicer but I don't want to do this for every object I place in.
I was told it's possible to move the MIN switch to the MAX plug on the mainboard but when I did and enabled the MAX endstop in the firmware it's asking me to define the PIN. I have no idea what to do at this point.
Here's a pastebin of my config before I messed around with lines I probably shouldn't have touched. http://pastebin.com/Zz8cix1D I've reverted back my changes.
