Firmware stop / reset under Auto leveling
Hi
On my Delta printer the firmware (0.92.9) simply stop everything after some auto level measuring point. Not finishing the autolevel....
If I set it to 3 point autolevel or n*n point autolevel it stop after 4 point in n*n, no communication and control board simply halt....
No reaction on at key/display input or from host commands, I have to disconnect and connect again with the host.
If I set P1, P2 and P3 for the autolevel to other coordinates, autolevel is working.
Problem is the P1, P2, and P3 has to be relative near to each other (short distance between them), so the autolevel will only cover the middle of the bed and not outer area.
Most of the time the printer stop in middle of auto leveling and reset.....
I cannot go longer out from center of bed then:
P1: -20,-40 P2: 40,-40 P3: -20,40 (X,Y)
Larger numbers halt the process and reset the printer....
My bed is 260mm in diameter.
Anybody have an explanation for that?
