Z-probe failed. DaVinci 2.0
i got some issue with the autoleveling from the heatbed with my davinci 2.0.
today i printed some things and then i wanted to recalibrate the heatbed with the autoleveling.
but i always get this message:
03:13:02.465 : Error:Z-probe failed
03:13:03.594 : N195 M105*42
03:13:05.025 : fatal:G30 probing failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
03:13:05.088 : SelectExtruder:0
03:13:09.355 : N196 M999*36
03:13:09.355 : N1 M110*34
03:13:09.716 : N2 M105*37
03:13:12.770 : N3 M105*36
03:13:13.604 : X:0.00 Y:0.00 Z:0.000 E:0.0000
03:13:13.662 : fatal:G30 probing failed! Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
03:13:13.664 : DebugLevel:6
03:13:13.665 : info:Continue from fatal state
the sensor for the bedleveling touch the bed.
i also tried to set the bed a bit higher or lower, but still the same message.
if it is possilbe, pls answer me in german.
  • Es gibt mehrere Gründe. Es kann sein das die Probe nicht aktiviert werden kann weil man am rand steht und der Extruder sich bewegen muss um die Probe zu aktivieren, aber gar kein Platz da ist. Mal
    G1 X50 Y50
    und dann messen.
    Auch schlägt es fehl, wenn die Probe bereits aktiviert ist bevor er nach unten fährt oder wenn sie nach dem Hochfahren immer noch aktiv ist. Mit M119 kannst du das kontrollieren. L = nicht aktiv, H = aktiv.
  • edited February 2017
    thanks for answer in german. i still write in english, cause i think this is easier for you.
    with m119 it says L when the extruder is in home position. during the autoleveling i can't use the command.
    i tried it with g1 x50 y50, but the extruder goes to home position when i start the autoleveling, heat and then he tries to measure.
    so, it still failed.
    this morning i tried to the autoleveling and at the first time he did it. at the second try it failed again.
  • Update:
    Sometimes i can autoleveling, but at the last point, the 3., it show's me the measure and after one second that it failed to touch z.
    all points are at 5mm +0,1. but i cant save it to eeprom cause the last "failtouch".
    also i noticed that sometimes during the autoleveling the printer push hard the bed against the sensor. then i get the wrong measure of 4,6mm.
  • Deutsch ist mein Muttersprache und wir sind eine deutsche Firma, also kein Problem.
    Was für ein Sensor ist das? Wenn er immer homed for dem autoelevling hast du vermitlich z max homing. Erhöhe mal z probe bed distance etwas. Irgendwie scheintst du das Bett schon vorher zu berühren was zum abbruch beim 3. Punkt führt, da hilft normal den Abstand zu erhöhen.
  • welcher parameter ist das denn im eeprom?
    16:58:33.831 : EPR:0 1028 1 Language
    16:58:33.900 : EPR:2 75 230400 Baudrate
    16:58:33.919 : EPR:0 1125 1 Display Mode:
    16:58:33.931 : EPR:0 1119 1 Light On:
    16:58:33.945 : EPR:0 1127 1 Keep Light On:
    16:58:33.955 : EPR:0 1126 0 Filament Sensor On:
    16:58:33.960 : EPR:0 1176 0 Top Sensor On:
    16:58:33.963 : EPR:0 1120 0 Sound On:
    16:58:33.967 : EPR:3 129 119.754 Filament printed [m]
    16:58:33.970 : EPR:2 125 153633 Printer active [s]
    16:58:33.978 : EPR:2 79 0 Max. inactive time [ms,0=off]
    16:58:33.980 : EPR:2 83 360000 Stop stepper after inactivity [ms,0=off]
    16:58:33.981 : EPR:2 1121 0 Powersave after [ms,0=off]:
    16:58:33.983 : EPR:3 1160 180.000 Temp Ext PLA:
    16:58:33.984 : EPR:3 1164 230.000 Temp Ext ABS:
    16:58:33.986 : EPR:3 1168 60.000 Temp Bed PLA:
    16:58:33.987 : EPR:3 1172 90.000 Temp Bed ABS:
    16:58:33.989 : EPR:3 1179 2.000 Load Feed Rate:
    16:58:33.991 : EPR:3 1183 4.000 Unload Feed Rate:
    16:58:33.992 : EPR:3 1187 60.000 Unload/Load Distance:
    16:58:33.994 : EPR:3 3 80.0000 X-axis steps per mm
    16:58:33.995 : EPR:3 7 80.0000 Y-axis steps per mm
    16:58:33.997 : EPR:3 11 2560.0000 Z-axis steps per mm
    16:58:33.999 : EPR:3 15 200.000 X-axis max. feedrate [mm/s]
    16:58:34.000 : EPR:3 19 200.000 Y-axis max. feedrate [mm/s]
    16:58:34.002 : EPR:3 23 5.000 Z-axis max. feedrate [mm/s]
    16:58:34.004 : EPR:3 27 40.000 X-axis homing feedrate [mm/s]
    16:58:34.006 : EPR:3 31 40.000 Y-axis homing feedrate [mm/s]
    16:58:34.008 : EPR:3 35 4.000 Z-axis homing feedrate [mm/s]
    16:58:34.012 : EPR:3 39 20.000 Max. jerk [mm/s]
    16:58:34.014 : EPR:3 47 0.342 Max. Z-jerk [mm/s]
    16:58:34.015 : EPR:3 133 0.000 X min pos [mm]
    16:58:34.017 : EPR:3 137 0.000 Y min pos [mm]
    16:58:34.019 : EPR:3 141 0.000 Z min pos [mm]
    16:58:34.020 : EPR:3 145 199.000 X max length [mm]
    16:58:34.022 : EPR:3 149 204.000 Y max length [mm]
    16:58:34.024 : EPR:3 153 200.000 Z max length [mm]
    16:58:34.025 : EPR:3 51 1000.000 X-axis acceleration [mm/s^2]
    16:58:34.027 : EPR:3 55 1000.000 Y-axis acceleration [mm/s^2]
    16:58:34.029 : EPR:3 59 100.000 Z-axis acceleration [mm/s^2]
    16:58:34.037 : EPR:3 63 1000.000 X-axis travel acceleration [mm/s^2]
    16:58:34.046 : EPR:3 67 1000.000 Y-axis travel acceleration [mm/s^2]
    16:58:34.058 : EPR:3 71 150.000 Z-axis travel acceleration [mm/s^2]
    16:58:34.061 : EPR:3 1024 0.000 Coating thickness [mm]
    16:58:34.069 : EPR:3 1128 100.000 Manual-probe X1 [mm]
    16:58:34.081 : EPR:3 1132 180.000 Manual-probe Y1 [mm]
    16:58:34.100 : EPR:3 1136 100.000 Manual-probe X2 [mm]
    16:58:34.106 : EPR:3 1140 10.000 Manual-probe Y2 [mm]
    16:58:34.111 : EPR:3 1144 50.000 Manual-probe X3 [mm]
    16:58:34.115 : EPR:3 1148 95.000 Manual-probe Y3 [mm]
    16:58:34.118 : EPR:3 1152 150.000 Manual-probe X4 [mm]
    16:58:34.122 : EPR:3 1156 95.000 Manual-probe Y4 [mm]
    16:58:34.128 : EPR:3 808 0.540 Z-probe height [mm]
    16:58:34.132 : EPR:3 929 6.000 Max. z-probe - bed dist. [mm]
    16:58:34.134 : EPR:3 812 1.000 Z-probe speed [mm/s]
    16:58:34.136 : EPR:3 840 30.000 Z-probe x-y-speed [mm/s]
    16:58:34.139 : EPR:3 800 0.000 Z-probe offset x [mm]
    16:58:34.141 : EPR:3 804 0.000 Z-probe offset y [mm]
    16:58:34.147 : EPR:3 816 36.000 Z-probe X1 [mm]
    16:58:34.152 : EPR:3 820 -7.000 Z-probe Y1 [mm]
    16:58:34.155 : EPR:3 824 36.000 Z-probe X2 [mm]
    16:58:34.162 : EPR:3 828 203.000 Z-probe Y2 [mm]
    16:58:34.165 : EPR:3 832 171.000 Z-probe X3 [mm]
    16:58:34.178 : EPR:3 836 203.000 Z-probe Y3 [mm]
    16:58:34.182 : EPR:3 1036 0.000 Z-probe bending correction A [mm]
    16:58:34.187 : EPR:3 1040 0.000 Z-probe bending correction B [mm]
    16:58:34.199 : EPR:3 1044 0.000 Z-probe bending correction C [mm]
    16:58:34.202 : EPR:0 880 0 Autolevel active (1/0)
    16:58:34.204 : EPR:0 106 2 Bed Heat Manager [0-3]
    16:58:34.207 : EPR:0 107 255 Bed PID drive max
    16:58:34.212 : EPR:0 124 80 Bed PID drive min
    16:58:34.217 : EPR:3 108 196.000 Bed PID P-gain
    16:58:34.224 : EPR:3 112 33.000 Bed PID I-gain
    16:58:34.230 : EPR:3 116 290.000 Bed PID D-gain
    16:58:34.238 : EPR:0 120 255 Bed PID max value [0-255]
    16:58:34.241 : EPR:0 1020 0 Enable retraction conversion [0/1]
    16:58:34.247 : EPR:3 992 3.000 Retraction length [mm]
    16:58:34.255 : EPR:3 996 13.000 Retraction length extruder switch [mm]
    16:58:34.261 : EPR:3 1000 40.000 Retraction speed [mm/s]
    16:58:34.268 : EPR:3 1004 0.000 Retraction z-lift [mm]
    16:58:34.274 : EPR:3 1008 0.000 Extra extrusion on undo retract [mm]
    16:58:34.283 : EPR:3 1012 0.000 Extra extrusion on undo switch retract [mm]
    16:58:34.295 : EPR:3 1016 20.000 Retraction undo speed
    16:58:34.303 : EPR:3 200 99.000 Extr.1 steps per mm
    16:58:34.306 : EPR:3 204 50.000 Extr.1 max. feedrate [mm/s]
    16:58:34.319 : EPR:3 208 20.000 Extr.1 start feedrate [mm/s]
    16:58:34.322 : EPR:3 212 5000.000 Extr.1 acceleration [mm/s^2]
    16:58:34.324 : EPR:0 216 3 Extr.1 heat manager [0-3]
    16:58:34.327 : EPR:0 217 230 Extr.1 PID drive max
    16:58:34.328 : EPR:0 245 40 Extr.1 PID drive min
    16:58:34.335 : EPR:3 218 3.0000 Extr.1 PID P-gain/dead-time
    16:58:34.342 : EPR:3 222 2.0000 Extr.1 PID I-gain
    16:58:34.346 : EPR:3 226 40.0000 Extr.1 PID D-gain
    16:58:34.354 : EPR:0 230 255 Extr.1 PID max value [0-255]
    16:58:34.360 : EPR:2 231 0 Extr.1 X-offset [steps]
    16:58:34.364 : EPR:2 235 0 Extr.1 Y-offset [steps]
    16:58:34.371 : EPR:2 290 0 Extr.1 Z-offset [steps]
    16:58:34.374 : EPR:1 239 1 Extr.1 temp. stabilize time [s]
    16:58:34.387 : EPR:1 250 150 Extr.1 temp. for retraction when heating [C]
    16:58:34.397 : EPR:1 252 0 Extr.1 distance to retract when heating [mm]
    16:58:34.404 : EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
    16:58:34.414 : EPR:3 246 0.000 Extr.1 advance L [0=off]
    16:58:34.420 : EPR:3 300 99.000 Extr.2 steps per mm
    16:58:34.432 : EPR:3 304 50.000 Extr.2 max. feedrate [mm/s]
    16:58:34.435 : EPR:3 308 20.000 Extr.2 start feedrate [mm/s]
    16:58:34.439 : EPR:3 312 5000.000 Extr.2 acceleration [mm/s^2]
    16:58:34.442 : EPR:0 316 3 Extr.2 heat manager [0-3]
    16:58:34.444 : EPR:0 317 230 Extr.2 PID drive max
    16:58:34.454 : EPR:0 345 40 Extr.2 PID drive min
    16:58:34.462 : EPR:3 318 3.0000 Extr.2 PID P-gain/dead-time
    16:58:34.465 : EPR:3 322 2.0000 Extr.2 PID I-gain
    16:58:34.468 : EPR:3 326 40.0000 Extr.2 PID D-gain
    16:58:34.470 : EPR:0 330 255 Extr.2 PID max value [0-255]
    16:58:34.476 : EPR:2 331 -2852 Extr.2 X-offset [steps]
    16:58:34.483 : EPR:2 335 12 Extr.2 Y-offset [steps]
    16:58:34.489 : EPR:2 390 0 Extr.2 Z-offset [steps]
    16:58:34.492 : EPR:1 339 1 Extr.2 temp. stabilize time [s]
    16:58:34.503 : EPR:1 350 150 Extr.2 temp. for retraction when heating [C]
    16:58:34.519 : EPR:1 352 0 Extr.2 distance to retract when heating [mm]
    16:58:34.522 : EPR:0 354 255 Extr.2 extruder cooler speed [0-255]
    16:58:34.534 : EPR:3 346 0.000 Extr.2 advance L [0=off]
    dies sind die einstellungen aus meinem eeprom.
    falls es diese einstellung ist "16:58:34.132 : EPR:3 929 6.000 Max. z-probe - bed dist. [mm]" habe ich sie schon um 2 mm erhöht, leider ohne erfolg. der sensor (taster) ist der selbe wie bei dem davinci 1.0: https://i.ytimg.com/vi/jjw9GcyP-JY/maxresdefault.jpg
    the thiny lillte thing, left from the nozzle.
    und aktueller stand ist der: wieder beim anfahren des ersten punktes kommt "z-probe failed" obwohl der deutlich den punkt berührt.
  • 16:58:34.132 : EPR:3 929 6.000 Max. z-probe - bed dist. [mm]
    Du must außerdem aufpassen von wo du startest. Wenn du die Probe nicht aktivieren kannst ohne anzuschlagen verweigert er schon am start. Am besten G1 X50 Y50 vorher um sicher zu sein das Platz zum wechsel ist. Und natürlich muss der erste Punkt erreichbar sein ohne anzuschlagen. Durch das aktivieren der Probe verschiebt sich ja der extruder und das passiert schon bei ganz anderen Koordinaten.
