Enable Fan when 3D Printer is not idle (?)
My 3D printer uses RAMPS 1.4 and everything works smoothly with the Repetier Firmware.
I am using an E3D hot end and I have set its fan to be "thermistor controlled" so it gets enabled when the hot end temperature exceeds 50°.
The Fan is connected to the "Heater 2 Pin - Normally used for extruder 1" and ...
I would like to ask if I can enable this fan when the machine is "not idle" and by "not idle" I mean the machine is moving,
heating the hot end, heating the bed.. whatever...
Is that possible?
Thank you
One Fan on the Hotend and one fan on the RAMPS plastic case. Both fans makes a lot of noise when they are working so I was thinking to have them both connected to the "Heater 2 Pin - Normally used for extruder 1" and enable them when the Machine is heating the bed or the hot end.
