not working light for LСD, board Ramps-FD
I want to use the display backlight to turn on the light in the chamber of the printer, put the parameter memory
#define CASE_LIGHTS_PIN  ORIG_FAN2_PIN
but after turning on the printer light does not turn on, try to turn the menu is switched on for 1 second and immediately OFF??
  • Make sure nothing else is using fan 2 pin like heaters or having second fan enabled.
  • Is there any way to control (switch on/off) case lights from reperiter host during print?
  • send
    M355 S1
    to enable and
    M355 S0
    to disable it.
