Problem with Simplify3D comments
I tested Simplify3D 3.1.1 in english but with OS in french.
The gcode genered containt some comments like this :
; G-Code generated by Simplify3D(R) Version 3.1.1
; févr. 4, 2017 at 2:26:54
When there is a character with a accent 'févr', the file print function not start with the firmware dev.
I'm not tried with 0.92
If I rename 'fevr', the print run without problem.
Is't possible to correct this ? but it's just unpleasant for 'février' and 'décembre'
I use just the gcode file on SD and print directly with the firmware
This remark was to alert the users, I spent a little time before understanding why the gcode file was no longer running.
I was just surprised that Repetier-Host avoids a comment line and that the firmware can no
Good job :-bd
