How do I get auto bed levelling to use the method that I set up?
Hi.
I have an Anet A8 running Repetier firmware with and inductive auto bed levelling sensor. I have set auto levelling up and it seems to be working but when I run the G32 command it probes the bed along diagonal lines from the front left to the back right corner of the bed meaning half the bed isn't being measured. I have set bed levelling method 0 in the configuration.h file (probes 3 corners) but it appears to be ignoring this and doing it its own way. How do I get the firmware to probe using level method 0 when I run the auto level command?
Thanks in advance!
