Anet A8 Extruder and heat bed not working
I have just installed Repetier Host V1.6.2 and i had some trouble connecting initially, but i can now have control over the axis and home funcitionanlity in the manual controls.
When i load a file, slice and print it, the extruder and heat bed do not work. The printer however follows the print path, but not filament is comng out.
I noticed in the manual control there was a red line across the heat bed and extruder, so i tired un-ticking them and it still didn't work.
Has anyone had this problem before? I need some help asap please
  • Disable easy mode and check if you have dry run activated, which prevents heating up.
