DEV version Gcode won't execute
The new DEV compile works without a heated bed but my Gcode doesn't execute.
I've heated the extruder and homed all the axes.. but the Gcode still won't work.
I am using an SD card and printing from my LCD panel. I have 4 extruders but I am only using and heating up one.
I have used the same Gcode files with the previous firmware and it worked.
How can I get the software to execute my Gcode even when I haven't heated the nozzle?
  • edited January 2017
    Also Gcode won't execute even if I am above Z0
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.0dev
       as you expect.
    #define NUM_EXTRUDER 4
    #define MOTHERBOARD 80
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 800
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 78
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 200
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 78
    #define EXT1_TEMPSENSOR_TYPE 8
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E0_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E0_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E0_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 200
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_PREHEAT_TEMP 190
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define EXT2_X_OFFSET 0
    #define EXT2_Y_OFFSET 0
    #define EXT2_Z_OFFSET 0
    #define EXT2_STEPS_PER_MM 78
    #define EXT2_TEMPSENSOR_TYPE 8
    #define EXT2_TEMPSENSOR_PIN TEMP_3_PIN
    #define EXT2_HEATER_PIN HEATER_3_PIN
    #define EXT2_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT2_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT2_INVERSE 1
    #define EXT2_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT2_ENABLE_ON 0
    #define EXT2_MIRROR_STEPPER 0
    #define EXT2_STEP2_PIN ORIG_E2_STEP_PIN
    #define EXT2_DIR2_PIN ORIG_E2_DIR_PIN
    #define EXT2_INVERSE2 0
    #define EXT2_ENABLE2_PIN ORIG_E2_ENABLE_PIN
    #define EXT2_MAX_FEEDRATE 200
    #define EXT2_MAX_START_FEEDRATE 20
    #define EXT2_MAX_ACCELERATION 5000
    #define EXT2_HEAT_MANAGER 3
    #define EXT2_PREHEAT_TEMP 190
    #define EXT2_WATCHPERIOD 1
    #define EXT2_PID_INTEGRAL_DRIVE_MAX 230
    #define EXT2_PID_INTEGRAL_DRIVE_MIN 40
    #define EXT2_PID_PGAIN_OR_DEAD_TIME 7
    #define EXT2_PID_I 2
    #define EXT2_PID_D 40
    #define EXT2_PID_MAX 255
    #define EXT2_ADVANCE_K 0
    #define EXT2_ADVANCE_L 0
    #define EXT2_ADVANCE_BACKLASH_STEPS 0
    #define EXT2_WAIT_RETRACT_TEMP 150
    #define EXT2_WAIT_RETRACT_UNITS 0
    #define EXT2_SELECT_COMMANDS ""
    #define EXT2_DESELECT_COMMANDS ""
    #define EXT2_EXTRUDER_COOLER_PIN -1
    #define EXT2_EXTRUDER_COOLER_SPEED 255
    #define EXT2_DECOUPLE_TEST_PERIOD 12000
    #define EXT2_JAM_PIN -1
    #define EXT2_JAM_PULLUP 0
    #define EXT3_X_OFFSET 0
    #define EXT3_Y_OFFSET 0
    #define EXT3_Z_OFFSET 0
    #define EXT3_STEPS_PER_MM 78
    #define EXT3_TEMPSENSOR_TYPE 8
    #define EXT3_TEMPSENSOR_PIN 12
    #define EXT3_HEATER_PIN ORIG_FAN2_PIN
    #define EXT3_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT3_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT3_INVERSE 0
    #define EXT3_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT3_ENABLE_ON 0
    #define EXT3_MIRROR_STEPPER 0
    #define EXT3_STEP2_PIN ORIG_E3_STEP_PIN
    #define EXT3_DIR2_PIN ORIG_E3_DIR_PIN
    #define EXT3_INVERSE2 0
    #define EXT3_ENABLE2_PIN ORIG_E3_ENABLE_PIN
    #define EXT3_MAX_FEEDRATE 200
    #define EXT3_MAX_START_FEEDRATE 20
    #define EXT3_MAX_ACCELERATION 5000
    #define EXT3_HEAT_MANAGER 3
    #define EXT3_PREHEAT_TEMP 190
    #define EXT3_WATCHPERIOD 1
    #define EXT3_PID_INTEGRAL_DRIVE_MAX 230
    #define EXT3_PID_INTEGRAL_DRIVE_MIN 40
    #define EXT3_PID_PGAIN_OR_DEAD_TIME 7
    #define EXT3_PID_I 2
    #define EXT3_PID_D 40
    #define EXT3_PID_MAX 255
    #define EXT3_ADVANCE_K 0
    #define EXT3_ADVANCE_L 0
    #define EXT3_ADVANCE_BACKLASH_STEPS 0
    #define EXT3_WAIT_RETRACT_TEMP 150
    #define EXT3_WAIT_RETRACT_UNITS 0
    #define EXT3_SELECT_COMMANDS ""
    #define EXT3_DESELECT_COMMANDS ""
    #define EXT3_EXTRUDER_COOLER_PIN -1
    #define EXT3_EXTRUDER_COOLER_SPEED 255
    #define EXT3_DECOUPLE_TEST_PERIOD 12000
    #define EXT3_JAM_PIN -1
    #define EXT3_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  20
    #define FILAMENTCHANGE_REHOME 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 0
    #define HEATED_BED_MAX_TEMP 90
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SET_INTERVAL 3000
    #define HEATED_BED_HEAT_MANAGER 2
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 170
    #define MAXTEMP 255
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 1
    #define DISABLE_E 1
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 435
    #define Y_MAX_LENGTH 430
    #define Z_MAX_LENGTH 680
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define Z2_MINMAX_PIN -1
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 7.3
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E2_STEP_PIN
    #define X2_DIR_PIN    ORIG_E2_DIR_PIN
    #define X2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define Y2_STEP_PIN   ORIG_E2_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E2_DIR_PIN
    #define Y2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define Z2_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z2_ENABLE_PIN ORIG_E2_ENABLE_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 1
    #define SERVO0_PIN 5
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 1
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 2.11
    #define Z_PROBE_Y_OFFSET 46.33
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 80
    #define Z_PROBE_SWITCHING_DISTANCE 3
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_HEIGHT 10
    #define Z_PROBE_START_SCRIPT "M340 P0 S680"
    #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "The Beast"
    #define UI_PRINTER_COMPANY "cultivate3d.com"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_DYNAMIC_ENCODER_SPEED 0
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define UI_SET_EXTRUDER_RETRACT_DISTANCE 10
    #define NUM_MOTOR_DRIVERS 0
    #endif
  • > I've heated the extruder and homed all the axes.. but the Gcode still won't work.
    That sounds like you could execute some gcodes or how did you do that?
    What does log show and what exactly are you trying to execute - consider that heating has blocking commands until temperature is reached.
