OLED SW_SPI DUE RADDS1.5
Hello Repetier Useres,
i try to implement a SSD1306 OLED SPI Display to my Printer by using the Repetier Firmware an got some issues. I'm use a Arduino DUE + Radds 1.5 interface in my Printer, for the tests only the DUE.
So on Step by Step. To be sure the Display Works fine i Download the last Version of the normal u8glib and try the "Hello World". Like the guy in the YouTube Video (Search for: DUE OLED U8GLIB Time: 17sek.) i added the Pin 48 in the Routine. As you can see, allready with the Display Pin configuration from the RADDS board.
If i do so, the Display works.
U8GLIB_SSD1306_128X64 u8g(44, 45,48, 46, 47); // SW SPI Com: SCK = 13, MOSI = 11, DON'T KNOW, CS = 10, A0 = 9
Display Pins are : VCC, GND, CLK, MOSI, CS, D/C
Why i have to add the Pin.....really don't know but without the Display will be Black
Now i try the same with repetier Firmware. So on i create a brand new Sourcecode via Repetier-Firmware 0.92.x with Configuration Tool and only chose
- Arduino DUE based board
- RADDS
Next Step
- FEATURE_CONTROLLER =1
and in the UIConfig.h
#define UI_DISPLAY_D0_PIN -1 // PINF.5, 92, D_D4
#define UI_DISPLAY_D1_PIN -1 // PINK.2, 87, D_D5
#define UI_DISPLAY_D2_PIN -1 // PINL.5, 40, D_D6
#define UI_DISPLAY_D3_PIN -1 // PINK.4, 85, D_D7
#define UI_DISPLAY_D5_PIN -1 // PINK.2, 87, D_D5
#define UI_DISPLAY_D6_PIN -1 // PINL.5, 40, D_D6
#define UI_DISPLAY_D7_PIN -1 // PINK.4, 85, D_D7
#define UI_DELAYPERCHAR 50
// Special pins for some u8g driven display
#define UI_DISPLAY_CS1 -1
#define UI_DISPLAY_CS2 -1
#define UI_DISPLAY_DI -1
#define UI_DISPLAY_RW_PIN -1
#define UI_DISPLAY_D4_PIN 44 // PINF.5, 92, D_D4 // SCK Pin: UI_DISPLAY_D4_PIN
#define UI_DISPLAY_ENABLE_PIN 45 // PINK.3, 86, D_E // Mosi Pin: UI_DISPLAY_ENABLE_PIN
#define UI_DISPLAY_RS_PIN 46 // PINK.1, 88, D_RS // CD Pin: UI_DISPLAY_RS_PIN
#define UI_DISPLAY_RESET_PIN 47
Code will Compile, but the Display don't Show something
so i have to dig deeper and look in the ui.cpp and see the Funktion
#ifdef U8GLIB_SSD1306_SW_SPI
u8g_InitSPI(&u8g,&u8g_dev_ssd1306_128x64_sw_spi, UI_DISPLAY_D4_PIN, UI_DISPLAY_ENABLE_PIN, U8G_PIN_NONE, U8G_PIN_NONE);
why the Funktion hast two "None" Pins ? If i compare with the "Hello World" and use the Variable Value i got:
repetier:
u8g_InitSPI(&u8g,&u8g_dev_ssd1306_128x64_sw_spi, 44, 45, NONE, NONE);
Hello World:
Can please someone help me so make the right definitions to get the Display running?
Thanks a Lot,
Axel
