"Z Probe did not untrigger" error
I'll be grateful for assistance please.
If I import the attached config into a recent dev configuration tool, I get a "Z Probe did not untrigger" error on the first probe when I use G32, however if I use it in a dev firmware downloaded on 16 Oct 2016 which I still have on my PC, I don't get the error.
I've tried increase the height as suggested by the error message but it doesn't make any difference.
configuration.h
  • Have you tried M119 and see if message is correct and also tried G30 stand alone?
  • yes, sorry I forgot to mention that the z probe triggers correctly with M119, I'll try G30 when the current print is finished.
  • I find G32 works fine on the latest dev version as long as the probe is above trigger height  before sending G32
