SD Card Error? - Da Vinci 1.0
Hi all,
So the story goes that today I had just finished a print when my Da Vinci 1.0 flashed with 0.92 decided to bottom out on the z axis. I quickly turned it off to stop this, however now it doesn't seem to work. Keeps coming up with SD Card Inserted, also no lights and won't begin a print. Still heats up, can be controlled manually and be homed using rep host.
The rep host logs constantly flicker between SD card inserted and SD init fail.
Cheers
Cheers
