Bed Leveling Issues (X Axis) Help!!
Hello I hope someone can assist me with this issue.. as i've been spending countless hours on trying to figure it out..
(my poor daughter hates the 3d printer now as she see's I'm obsessed with it
I installed a Hall-o z probe sensor on a Rostock mini in efforts to use the auto leveling feature of Repetier .92
The probe it working as expected. However when i try to do an auto level via G29 or G32 or G32 S2
the X's Z axis is always lower than the Z axis near Y & Z... in fact the Z access (near Y&Z) seem to be the same height..
its just the X's Z position that is always lower by say 10mm....
so when it goes through its calibration process the the Z height near the X axis starts off at say 5mm and slopes up towards the Y axis to 10mm
then heads towards the Z axis at the same 10mm..
I also already made sure all 3 carriages were at the same height from top to bottom.
Another question i had relates to the Z probe being hooked up to z-min; i noticed that when the z probe triggers it stops the z axis (until it retracts fully) causing the printer head to drag along with the X&Y movements only... is this normal?
